25hp Nissan prop doesn't turn and water pump will not pump
racarpent
I've meesed with outboards a while this is the first I've seen where both prop and water pump don't work. I assume it is drive shaft related. Just quit working will motoring no other symptoms. Motor still idles fine.
pvanv
Re: 25hp Nissan prop doesn't turn and water pump will not pump
What is your model? If you drop the LU, is the driveshaft in one piece?
TOHATSU GURU
The two things are independent of each other. So, unless you have a broken drive shaft, the problems are not related.
racarpent
NS25C3 2001 I'm not sure, I did notice there didn't seem to be any splines or a key just a smooth shaft.....
pvanv
Are you saying the top end of the driveshaft doesn't have splines? If so, it is probably snapped off, with the splined portion stuck in the crankshaft.
