Hi Guys, I hope someone can help me here cause I'm stumped!
My 25hp mercury circa 1992 had been going great. Left for a couple of months over winter. Started OK. Ran fine with flushing ears. When put in the water it would not rev hard enough to get the tinny onto the plane.
It was running great the last time it was used.
Did these things:
Checked and changed Fuel
Had mechanic check electrics. One coil tested weak so it was replaced.
New spark plugs
Sand found in filter and fuel tank - Carby cleaned with new Kit put in. - tank cleaned.
External filter between engine and tank fitted.
After all this the motor started and ran exceptionally sweet at idle and free revving with flushing ears.
Put it in the water and it did exactly the same thing - It ran sweet at low revs but rough at higher revs and would not rev enough to pull onto the plane.
Next steps: Checked prop. - Fine
Checked spark advance and timing. - Perfect
While revving under load in test tank, pumped primer on fuel hose - not difference
While revving under load in test tank, pinched fuel hose between filter and carby -
Bingo! The motor revved up and pulled like mad to full power!!
The diagnoses was thought to be running too rich on the high speed jet phase but we can't work out why. The jet has not been changed other than a new needle. (it just got a new kit in it but did the same thing before the kit was installed.)
There are no obvious leaks in the carby (it just got a new kit in it but did the same thing before the kit was installed.)
Any suggestions? We are at a loss........
Thanks. Andrew
Did these things:
New spark plugs
Thanks. Andrew
