Stimulus-Plan
- Jul 14, 2010
- 4
First of all let me say thank you to all that have contributed to a GREAT site... I have spent hours reading posts and have learned a lot along the way!
Well, Our second boat and love it but we all know used boats need attention so here goes my symptoms.
1990 270 Thompson Daytona w/twin 4.3 mercs...
Engines are a bit tired. compression averages 100 psi +/- 5%. need to do a leak down test to see if rings or in the heads. Hoping heads
Should have squirted a bit of oil in the cylinder while doing the compression test huh?
Need to run 3800 RPM's to hold a good plane, with light load, and only doing around 24mph with 4 blade aluminum props. I never checked the pitch when I bought it. Usually jumps on plane quickly. I think if I step up the pitch it will be to much work on the motors to get on plane.
Jumped on throttle last weekend out of the hole and starboard engine went past 5000rpm's while port stayed around 4400. The weekend before we went out late at night and was running around 4000rpm's on plane with 4 people and gear. Starboard engine got a bit hot. Thinking impeller. Noticed a burnt rubber smell when we beached so I'm guessing my engine coupler(starboard side) is slipping
. Would have thought prop hub if no smell... got to the island and let it cool for about an hour. started it up and idled up around 1200-1300 and temp pulled right back down. Could be water pump/clogged risers, etc. but where I dock is shallow and believe I'm sucking a lot of sand and it is eating the impellers up. Overheating that night may have been due to an impeller vane/piece lodged in the water passage way. On the way back to the slip I was easy on it and ran fine. Didn't seem to slip but I babied it. At low idle though temp likes to climb slowly.
Ok, so from what I have described so far, What course of action do you guys recommend? I'm a backyard mechanic and have re-built 6 or so engines in cars and trucks. A few differences in marine engines but I will tackle that this winter. Still hoping heads though
Taking her out of the water will cost me $100 alone so trying to get around that. I hope the impellers last the rest of this season or it will have to come out.
So should I just take it easy on her or start troubleshooting some certain areas now? Sorry about rambling on but trying to give as much insight as possible.
Appreciate any advice you guys/gals can offer.
