Re: 25hp johnson
Not sure on your year but on my mid 70's 25 hp you have to undo the shifter shaft. On my motor there is a cover on the side of the motor about half way up. Held on by two screws. Remove this palte and under it is the shifter shafts. Remove the bottom bolt so you can seperate the shafts. May have to have the engine in forward to do so.<br /><br />Hope this helps.
