Cordovakid
Thread starter- Joined
- Sep 28, 2012
- 30
Hey Guys - my 1980/81 25hp Merc is very, VERY difficult to cold start. Warm is OK - only one pull needed. But cold starts are not nice. I have the OEM Svc. Manual, but not the owner's manual, so I don't have access to the "OEM Starting Procedure", as it were. This model has a Tillotson BC1C carb, with the plunger-type enricher built into the carb, which is depressed by an arm when the idle knob is turned all the way clockwise to a higher idle speed. I understand this particular type of enricher operates on a vacuum principle, by pulling the fuel into the carb instead of pumping it in like a push/pull type of knob.
Anyway, since there's no formal "choke", I don't know if I'm flooding it or not giving it enough fuel most of the time, but after 25 pulls or so, it'll start. I typically turn the primer "on" four or five times and then leave it there with the plunger depressed, and try to start 'er up. Sometimes I will deactivate the plunger and just leave it on high idle to get it going, but doesn't seem to make much difference. I realize it probably needs a carb / fuel pump cleaning, which I will do in the spring, but for now I would like to make sure I look at the easy things first.
Does anyone have access to (or knowledge of) the "correct" starting procedure for one of these types of older enricher carbs? My right arm thanks you...
