25E78C installing a key switch on a tiller converted to remote help
Pin.man
I have the wire diagram I just don't know where to tap the wire harness to install the switch? It has not had a remote wire harness, I have made my own. Do I just splice it in or do I have to cut and connect? Any help will be great! Motor had an installed push button start wired to the solenoid and I left the battery hooked up now it won't fire at all, I replaced the CDI and plugs plus checked all grounds and connections, still no fire any hints? If not I guess I'll replace the 2 coil packs and try it again!! Any help would be great
Joe Reeves
Unfortunately you're asking a variation of questions pertaining to problems that may or may not be of your own making. You're going to need to explain in detail what you may have done before this "no fire" condition popped up. Simply leaving the battery connected, if the wiring is correct, will not interfere or damage the ignition system.
Did you actually remove the spark plugs, rig a spark tester whereas you could set a 7/16" gap for the spark to jump... OR... are you simply assuming there is no spark because the engine will not start. NOTE that the 7/16" gap is important as the spark should jump that gap with a strong blue lightning like flame... a real SNAP!...... DO NOT attempt to use the spark plugs to test for spark as that's a waste of time!
Was the engine running and starting properly previously?...... Did you do any work at all on the engine and then discover that it would not start?
Did you connect anything to the Black/Yellow wire that leads to the power-pack... and If so, what?
