FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
My 930 250 is stuck from siing. It was running fine 2 months ago. I took the plugs out and put 2 stroke oil in the cylinders. What size nut is on the flywheel so I can try a socket and breaker bar?
Its probably going to be big and metric.Why not just buy a socket set from sears or lowes or where ever ? Make sure its a 6 point set to reduce rounding off the bolt corners.
I pulled the head and the #5 cylinder had some rust and salt in it. It didn't come from the head so maybe from the exhaust plate. Once I free up the motor I'll look further.
Soak in marvel mystery oil for several days.Shoot some into each plug hole. Open the throttles by hand and shoot some down each throat.
Big Suzuki's are 32MM. Measure across the nut flats or points to get an Idea of size then go to Sears and get a socket. You can take it back if it doesn't fit.
