25 Yami Tiller Tensioning Screw Stripped
OceanSun
I've managed to strip out the threads where the steering tension bolt is. What is the best way to fix this? Can it be tapped out and a new, larger bolt installed. Are larger bolts with the threadless end available? Will i need to make one and machine the threads off the end and pollish the end of the bolt where it lands to apply steering tension? Is there a temporary fix you could suggest?<br /><br />Any help and suggestions greatly appreciated. Thanks!
JB
Re: 25 Yami Tiller Tensioning Screw Stripped
Sounds to me like you have a plan. That's what I would do.<br /><br />You will probably need to modify a SS bolt to match the old one.<br /><br />Good luck. :)
