25 hp tiller steer yamaha prop???
easttexan
has an aluminuim prop now and want to get a stainless. dont know what size i need to get though.it says 9 7/8 x 10 1/2-f. its on a 1650 express. i want a little more take off speed. any help will be GREATLY apreciatted. thanks alot
steelespike
Re: 25 hp tiller steer yamaha prop???
Is the motor a 2 stroke or 4 stroke?What year?Welcome we need more info.If you read the stickies at the top of the page and the helps at the prop store page it will help yopu understand prop selection a little better. We need yor present max rpm and speed to do it right. A tinytach is $40 and easy to install.A gps is excellent for speed.The motor needs to opewrate within its rated rpm range.
A stainless is uneccessary and complicates selection when going from aluminum.
easttexan
its a four stroke and its an 04' it runs 20 mph. i dont know about the rpm's. i want a stainless cause when i hit stumps ALOT. and i hit rocks in the river. and its takin a toll on this aluminum prop.
steelespike
It might work for stumps but rocks you better check with the others that boat in the area.I'm guessing a ss is 2 to 3 times the cost of al and probably twice the cost to repair.Usually refered to as soft contact.sand and mud not rocks and stumps.Maybe I missed something. If your hub doesn't work right ss transmits more stress to the gearcase.
