25 hp mercury 2001
Mustfish
I have a motor that if I throttle up slow the motor boggs. If I throttle up fast the motor stops. If I throttle up slow and it starts to bogg I have to pull the primer out and push it back in and then the motor takes off. This happens about 90% of the time. The motor will troll all day long. Is this a carburater or a fuel pump problem? HELP!!!
Thanks
Laddies
Banned
Re: 25 hp mercury 2001
the carb is dirty probable a clogged high speed clean it or you can damage the engine
jimlad
laddies right you cant beat doing manually i used sewing needle and fuel to clean the jets but be careful you dont make the holes any bigger make sure float is ok they can split wherer the to halfs join its hard to see and will keep adding fuel d:)
Mustfish
Laddies /Jimlad Thanks for the feed back ! I will clean carb. before taking out on water. Thanks again!! Laddies I'am also in Michigan southern be awhile before I can test it. 8)
Mustfish
Hi! Seafoam carb. cleaner any opinions on this? I'am still going to clean jet manuelly/ motor ran this way out of show room was told it needs to be brokein and the double oil mixture was the problem! I think jet may be bad ?? Thanks!
Laddies
Banned
The only way to clean a carb is to take it apart and do the job right, on this forum some seem to think decarb with seafoam will repair anything, I wonder if they drink the stuff? Bob
Mustfish
Mustfish
Laddies Thanks, i thought it was to good to be true.
