when you say switch the stator wires. there are a pair of brown wires and a pair of black wires coming from under the flywheel to the switchbox. it is a 1985If the coils are good, then the switch box or stator will be the problem. Try switching the stator wires from the stator to the switchbox. If no change the box is bad. Make sure the plugs are removed from the block and ground them to the block with a piece of wire. If your motor is a point ingnition motor (older than 1976) the above test dose not apply.
Oldman570
