25 hp Johnson stalls
windell
Here's my problem. I have a 2002 Johnson 25 hp tiller. It runs great but often, while I run it full throttle, the motor just dies. It doesn't bog down, spit or sputter, or anything like that. It just dies. I put it back in neutral and it fires right back up and I'm on my way. Only does it when I hold it wide open. Fuel problem?
weezzell_5400
When it does die... do you have to pump your primer bulb again to get it to start ...if so it sounds like you have a fuel problem ...fuel tank vent....fuel pump...clogged filter...clogged lines....trash in the jets on carb ....one of these could be the culprit
windell
No I don't need to pump the primer. I'm thinking the filter or jets could be gummed up.
scout-j-m
Could possibly be a shorting wire in the kill circuit only caused by the ride quality or vibrations at WOT?
