I posted a few days back about a 25 horse Johnson (25R71S) I got that supposedly had a failed impeller and just quit due to overheating and low compression (50/60 psi). The cylinders were just as pretty as they could be, and the motor wasn't locked up.<br /><br />Original post <br /><br /> Well, I started taking it down today and found something that I suspect isn't supposed to happen. I started the dissassembly with the bottom end since I was told the impeller was ruined and I suspected it myself since the paint on the midsection was discolored like it had been very hot. I dropped it to get access to the impeller and immediately saw that everything inside the midesection had a deep layer of carbon caked on it like it had been subjected to pure, hot exhaust. In the deep cavity behind the impeller housing was a deposit about an inch deep in loose carbon particles and the shift rod and driveshaft were caked as well. The inside of the access cover where you separate the shift rod sections was black as coal as were the two retaining brackets on the shift rod. On top of the impeller housing is what I think used to be a rubber sleeve where the water tube joins and goes up into the engine with the cooling water. Well, that rubber sleeve is burnt to carbon and very brittle and hard. I'm assuming that's not a good thing, huh?<br /><br /> Now on to the impeller. I took that apart of course and when I opened it I saw what looked like a brand new rubber impeller with only a couple of hours on it. There was no melting, scarring, missing areas or anything else on it to suggest that it had failed. I was also careful to check to see if it had been properly mounted on the keyway after reading several posts here and there were marks suggesting that it had been rotating normally.<br /><br /> I'm just guessing here, but did a gasket let go on the exhaust system somewhere and then dump hot exhaust into the midsection where it wasn't supposed to be and cause the engine to overheat and quit? If that is what happened, did the exhaust pressurize the midsection forcing the lakewater out and the impeller to starve for water to cool the powerhead?<br /><br /> Teach me folks, I'm trying.<br /><br />Steve
