25 hp johnson 2000 need help with starter bracket part
Status
Not open for further replies.
813dragons
I have a 25 hp johnson, 2000 ... My part# for the starter bracket is 333929. This place sent me a part # 327730 saying that 333929 supercedes the 327730. but one of the bolt holes is a hair too short for the bolt to gain access and one bolt hole thats on the original bracket thats a threaded hole is not on the replacement bracket. why is this, and what can i do. is this the right part? it says its for a 1984 35hp. thanks
tashasdaddy
Re: 25 hp johnson 2000 need help with starter bracket part
this is what the BRP parts diagrams shows for your bracket.
Part Number: 0333929
Description: BRKT, EL STARTER
Pack Qty: 1
Dimensions: 7.50 x 7.25 x 5.75 (in)
Weight: 1.27 lbs
Equivalent Parts: N/A
as you can see there is no equivalent part. it is direct replacement.
tashasdaddy
i definately would return the part. sounds like ebay.
jasper60103
Several brackets will fit my motor ('81 25hp), including yours
per the BRP website.
Part Number: 0320012
Pack Qty: 1
Weight: 1.27 lbs
Equivalent Parts: 0327730,0331210,0333929
So it appears the part for your motor (333929) is backwards compatible,
i.e. will fit the older Johnsons,
but it doesn't work the other way around.
Poorjonboy82
would the that same bracket (model # 333929) fit a 72 evinrude 25 hp? the OMC bracket looks identical to it.
Status
