eurolarva
Thread starter- Joined
- Jun 24, 2003
- 4,182
The starter gear that spins the flywheel rides up on a shaft called a bendix. This bendix can get dirty and the gear may not be able to travel all the way up. Take a liberal amount of WD 40 and clean the bendix then when all the WD40 has dried oil the bendix with a light weight oil like 3 and 1.
Make sure all contacts are tight, clean and shiny. This includes all wires to the battery, starter and starter solinoid. If you have a DC volt meter check your battery voltage 12 hours after you have charged the battery. The voltage should be around 12.65 volts. If it reads around 12.45 volts battery is at the end of its life and it is time to get a new one.
If none of this helps the next step is to take the starter apart, clean it and reassemble it. It is usually carbon particles mixed with water that cause a sludge and can be cleaned with WD40(do not use oil or any other lubrication inside the starter) When reassembling the starter some mono filiment fishing line works well to hold the brushes in place when you put the cover over it. then cut the line.
Good luck
Good luck
