25 Horse Johnson recoil
jigemup
I have a 25 horse Jonhson Pull-start that is really slow to recoil. Any Ideas?
dew2
Re: 25 Horse Johnson recoil
Pull it off and clean it really good.probably old grease with debrie sand dirt clodded up in it.I use white lithium grease just a small amount after a good cleaning. Engine degreaser works pretty good.
samo_ott
You can also wind the spring up a turn or two if that doesn't work. But wear safety goggles whenever working with that spring!
kbait
I've removed recoil and squirted a bit of pb blaster in the holes where you see the spring and pull it a bunch of times. If it frees up nicely, I add a bit of white lithium grease to the spring through the same holes and use it. It's kind of a stop-gap, but it can un-gum the old grease and make it functional. It should be disassembled/cleaned/lubed lightly to do the job correctly, but there's nothing that can really break by quick-fixing it.
D
DJ
Guest
DON'T MESS WITH IT other than cleaning and lubricating.
If that spring lets go it's like trying to stuff wet cats into a bag to replace it.:eek:
jigemup
I use this boat in cold weather that is below freezing. Is OK to run that recoil without grease?
dew2
I'm in minnesota and thats why white lithium grease,dont clean and not grease you will then next time have to replace one rusted together spring.
