Scott Washington
Thread starter- Joined
- Jul 15, 2003
- 5
The model # is E25EERR<br />The Ser # is G 03616524<br /><br />Can you tell me the year? How to get a manual? and any advice on the fuel problem?<br /><br />First let me thank you all for the help so far. Here is the history: My first post<br /><br />I just bought a 25 horse short shaft evinrude. It is electric start and in fairly new condition. I think it was made around 96 although I don't know the exact year. I'm sure it has not been run for at least 4 years. I tried to start it and it started easily (with new gas and hose) but it would only run for about 3 seconds then it would die. It sounded like it was running out of gas. The water pump did work. It would not start at all without the choke (it has the kind where you push in the key to give choke). It readily starts and runs for 3 seconds as many times as you try to start it with the choke. One other thing. On my 15 horse Evinrude at the front of the carb there is something that looks like an "air horn" but this motor has nothing attached to the front of the carb but there are threads as if something should be bolted up there. Sorry I've been long winded. I'd love any advice I could get especially and exploded view of the motor.<br /><br />The Reply:<br /><br />Sounds like the 25 hp engine is in need of carburetor cleaning.Engines that have set out of use for long spells are prone to accumulating gummy deposits in fixed orifices and porting.The keyswitch button is a primer and allows fuel to flow past the carbs into the intake chamber.This would explain why it will only restart by pushing this button in.<br /><br />Don't know what year model 15 hp you have but it may be missing the air silencer cover. <br /><br />The new info:<br /><br />Well I pulled the starter so I could get to the carb. Once I got the carb off I cleaned using a bucket of carb and parts cleaner. It looked pretty bad before I cleaned it so I was sure it would run but when I got it all put back together it still wouldn't run. I wonder if it is because of the "needle" that runs down to the bottom of the carb. I'm not sure that needle got totally cleaned out and I'm not exactly sure how to get it cleaned out. The rest of the carb looks perfect. Basically It will run as long as you hold in the primer (the key) but when you take that off it dies in 3 - 5 seconds. I'd appreciate any advice.
