Scott Washington
Thread starter- Joined
- Jul 15, 2003
- 5
I just bought a 25 horse short shaft evinrude. It is electric start and in fairly new condition. I think it was made around 96 although I don't know the exact year. I'm sure it has not been run for at least 4 years. I tried to start it and it started easily (with new gas and hose) but it would only run for about 3 seconds then it would die. It sounded like it was running out of gas. The water pump did work. It would not start at all without the choke (it has the kind where you push in the key to give choke). It readily starts and runs for 3 seconds as many times as you try to start it with the choke. One other thing. On my 15 horse Evinrude at the front of the carb there is something that looks like an "air horn" but this motor has nothing attached to the front of the carb but there are threads as if something should be bolted up there. Sorry I've been long winded. I'd love any advice I could get especially and exploded view of the motor.
