25 evinrude cutting out at wot
JohnnyO3
My ‘95 25hp evinrude starts, idles, trolls perfectly. At wot it runs great for a few minutes then it’s like one cyl cuts out. Shakes violently and won’t speed up. It may clear up for a bit and do it again. Sometimes revving it in neutral or shutting off and restarting clears it up briefly. New impeller as I thought it was slow mode. New powerpak and coils let year
What boat ?---What prop ?-----Perhaps hitting the rev limiter if powerpack has that feature?------I can not see or hear your motor.
rowerowe101
Sounds like a fuel restriction, maybe needle sticking or something similar if it's carbuerated.
JohnnyO3
As previously mentioned it doesn’t go away when slowing down so it’s not fuel starvation.
oldboat1
I would want to see if it's losing spark on the lower cylinder at WOT, or thereabouts. You might hook up a timing light to see -- no flash, no spark.
Also, check the prop. Make sure the prop nut is locked down and the spacer is in place.
