Re: 24Volt Boat Lift Motor + 10watt Solar Panel ??? Electric guys?
What he is planning on is a parallel series circuit and it is doable, pretty easy also but you will cut your output of the solar panel in half by doing it, now were talking about less then a trickle charger, I like his enthusiasm but you really need another solar panel which it sounds like you have, wire the batteries in series like he says, but wire each solar panel independently, one solar panel to each battery, I still recommend a controller but its obviously up to you.
All you are doing is charging each 12v battery with one solar panel, the fact that the batteries are in series doesn't matter unless your trying to charge them as a 24v system which you are not.
ugh think of it this way, lets say you have 4 6 volt batteries you want 24 volts so you wire the batteries positive to negative at the end of the system you have a negative on one side and a positive at the other(A series setup) if you measure these two points you will have roughly 24 volts but if you measure from the negative to the second battery positive you have 12 volts, now measure from the negative of the third battery to the last batteries positive and again you will have 12 volts even though the third battery is still tied to the whole battery system.
Now if you wire these same four batteries positive to positive and negative to negative with all four batteries you will have 6 volts (a parallel setup). The ideal charging system for a 24 volt system is a 24v charger but there are more then a few ways to skin a cat right?
