convergent
Thread starter- Joined
- May 17, 2010
- 385
I just picked up a new to me ProCraft 200 Combo tonight and it has a factory installed Motorguide 12/24V trolling motor. When I first looked at the boat, I thought I remembered the PO demoing that the trolling motor worked fine, and then when we went for a sea trial yesterday it would only work on 12V and turn very slowly. It has a 12/off/24v switch on the foot pedal. He thought it might be that one of the batteries was dead, but when I got the boat home tonight and checked it out I found that both batteries are showing 12.9V so that isn't the problem. I can probably eventually figure out how to trace this out, but I thought I'd ask here first. It has a four prong plug in the bow... what should be the voltage on the prongs? Assuming the voltage there is correct, what else might I want to check to diagnose this. The wiring is exposed under the pedal and there is the basic speed dial, on/off pedal, and the three position switch, so I could check those but not sure what I should be seeing on them. Any help would be appreciated... would like to break her in fishing on Saturday.
