24 volts at the generator 1966 40hp johnson ?
Clint R
I just tested my generator before the voltage regulator. Im getting 24-25 volts does this sound about right ? <br /><br />Thanks in adavance.<br /><br />clint
Joe Reeves
Re: 24 volts at the generator 1966 40hp johnson ?
Clint.... If you're actually reading 24 volts anywhere on that engine, you've got two 12 volt batteries hooked up in series. In which case, you've caused damage to various components.<br /><br />Hopefully you've got your meter set wrong which could double the actual voltage reading. 12 volts is the limit!
Clint R
Well I dont know whats going on then, Im sure my meter setting was right. But I will double check it tomorrow.<br /><br />I tested it just like you said.<br /><br />"You can test the generator itself by connecting a small jumper from the field terminal of the gen (smaller of the two terminals) to ground, then connect the positive lead of a volt meter to the gen armature terminal, and the volt meter ground terminal to ground. If the generator's okay, at idle of course, you'll see no charge, but as you increase rpms, the meter will register the voltage charge rate."<br />.................................................<br /><br />I hooked it up just like you said brought up the rpm's and held it at a steady rev and the meter was reading 24-25 volts. It showed no voltage at idle rpm's and took a few seconds of higher rpm's before it would showed the 24-25 volts.<br /><br />What should the voltage be on a good generator ?<br /><br />Thanks again Joe for the reply.<br />clint
