24 volt trolling motors
miss-fit
I just bought a 24 volt motor system which came with a 5 prong male socket on the end. I can't seem to find any of the female sockets anywhere. Also, while looking i noticed the 24 volt female sockets have 3 wires attached. What is the third wire for? I thought you would only need two, one for positive on one battery negative on the other battery and connect the two remaining terminals? Any thoughts would be great.
david_r
Re: 24 volt trolling motors
welcome to iboats!!!
5 prong??
what kind is it?
do you have a switch on the front panel for 12/24?
what other kind of accessories do you have on the front panel?
i never understood why there are so many different trolling motor wiring diagrams on boats.
my 12/24 had 4 wires and a 3 prong plug in... the same thing on 2 different boats.
the ranger my dad let me borrow has 4 wires and a 4 wire plug........ the male end is also 4 prong but the trolling motor only has 3 wires.
some pics and/or wire colors along with a little more info and we should be able to help you.
Silvertip
Honorary Supreme Mariner
If it is a 12 AND 24 volt motor there are three wires in the motor cable. If it is 24 volt ONLY, then there are only two wires so only a two wire plug/receptacle is needed. To save yourself time and frustration, remove the five prong plug and replace it and the receptacle with matching two or three prong units. One terminal is simply not used.
