24' pontoon 115 J/E
67-69johnman
I recently purchased a 24' lakes pontoon with a 115 johnson and i was just wondering what i can expect as far as performance. So far i've experienced about 18-20mph at WOT, is this close to your experiences? The toons are a little beaten though not severely and they do also have a pretty thick coat of "live in the lake" mud.
what is your opinion on this combination?
on this manufacturer of pontoons?
The Rooster
Ensign
Re: 24' pontoon 115 J/E
Not sure about the manufacturer, "Lakes Pontoons", but a 24' w/ 115 hp is usually good for 25 + mph. The tubes need to be clean and leak free. More details might help. Year of boat and motor. Prop size. RPM's @ WOT ?
Boss Hawg
Can't guess but i have a 20' with a 110 Johnson & it'll hit 30 no sweat---
crb478
I would expect it to get closer to 30 mph unless it is an older pontoon and motor. What year is the motor? If its pre 85 it is probably rated at the crank and not the prop so it could be closer to 95 or 100 hp. Also how clean are the toons? You can easily pick up 5mph with clean ones over grungy ones. you can scrub them clean in the witer with a nylon brush. What is your WOT? Props can make a big difference in pontoon speeds, I personally like four bladed props on pontoons. Lastly how much does the boat weigh? If it is real heavy it will not go as fast as a lighter model. I have a 1998 24 foot Crestliner pontoon with a 1986 Yamaha 115 and with clean toons in smooth water I have hit 31 mph on the gps at wot with two on board
67-69johnman
Its a 73 johnson 115 with a 3 blade prop. not sure the pitch but im fairly sure it has been on the boat since new since they are off similar years. so im guessing that the pitch of the prop is probably appropriate to the application.
also the data plate states that it is rated for 4500 rpm so im guessing its around that at WOT
The toons are extremely dirty they are so coated in this muck it almost looks like it was coated intentionally. (kinda looks like faded white rhino lining) but it does flake off, the toons also have a few dents and repairs here and there but are totally functional. i pulled the plugs on them the other day aafter the initial purchase and found water in the right tube.
Though not knowing when the last time was that they were pulled i cant really say what kind of a leak i have i drained it into a trash can and estimated it was about 10 gallons. i pulled it today after two allday uses and didnt find a drop. Also on that note the plugs weren't even hand tight in fact im surprised they hadnt fallen out, so i wrapped them in teflon tape and reinstalled
steelespike
If the muck is hard and flakes you might be able to carefully whack the tubes with rubber mallet just enough to loosen the muck.
If its older the tube diameter may be undersized.
crb478
I suspect the muck is slowing you down, it may or may not be easy to get off. If your plugs were loose that may be wher the leak was just keep and eye on it.
