233 mercruiser i/o with heat exchanger over heating
johnmorgan
I just bought a 26 foot campion toba the motor runs great, but on my first run it heated up to about 190.
so I powered down and it went down to 170. was wondering where to start looking for the problem.
the leg is supposed to be rebuilt looked great when i was buying the boat.
stonyloam
In any overheating situation, but especially with a heat exchanger I would suspect the impeller in the outdrive waterpump.
Bt Doctur
Just pull the drive and replace it. what you describe is usually a weak/failed impeller
Also pull the heat exchanger end caps and clean out the tubes
Darn I just launched it to, thank you guys for the help.
Any new to you boat should get a full maintenance treatment:
Raw water pump
Gimble bearing
Alignment
Bellows
Gear oil
Engine oil and filter
Fuel filter
Plugs, wires, cap, rotor
That way you know where youre at in the maintenance schedule
johnmorgan
Thanks for the advice scott and all the others I will be doing all of that now makes a lot of sense.
