fishman204
Thread starter- Joined
- Jun 2, 2013
- 43
Hello all I could use some help on my 96 ocean runner. This motor I bought used earlier this year looked very clean started rite up.But when I got her home she started lookin ruff. Took a while but I feel I'm close to running correctly.All new gaskets from carbs to intake manifolds to block 1 new head gasket new choke primer new thermostats then took to local marina for compression,leak down all good I also wanted them to adjust the carbs and check timing but they didn't before I picked her up they said the spark kind of bounced around on the plugs? Now when I start up on muffs runs a little off at idle and when we dunk the boat starts rite up on cold start idle drops a little then dies I've tried revving a few times it just runs crappy, then when you take off runs great from 2k to 5k rpm smooth as can be. I have the seloc manual I know they miss a few things. I hate to just throwing parts at it but I'm now leanig towards the power pack ps would u buy a mallory or omc thanks so much
