22 ft dynasty boat wont plane
maesj1
I have a 22ft dynasty boat (was used for towing)<br />that wount plane unless i have atlest 150 to 200 lbs in the front.Could it be my prop and if so what prop do I need
cobra 3.0
Re: 22 ft dynasty boat wont plane
How about giving us more info on what you have now? Motor, year, prop used now, top rpm now(WOT).
Jdeagro
iboats.com Partner
What is your RPMS & Speed at Full Throttle?
maesj1
1995 50 chevy motor it well red line and still wont plane
Boomyal
I'd suspect either a dirty hull or a cavitating prop. When you get near redline does the motor sound as if it is under load or could the prop be spinning in the air.<br /><br />Also you need to check your trim position. Another possibility is that you are carrying excess weight in the form of waterlogged foam.
steelespike
I dont know if an i/o has a rubber hub in the prop but if it does it may have a spun hub.<br />You can remove the prop and mark the hub,run it and check the mark.A prop shop can rehub the prop.
Boomyal
The fact is that maesj1 hasn't bothered to give enough information to begin to make an educated guess. :rolleyes:
