bsimon1975
Thread starter- Joined
- Sep 28, 2013
- 6
Just bought a 94 Cajun 2100 with a 94 Johnson 150 Ocean Runner....Ive read that porpoising is a problem with these boats that cant be corrected. Here are the Specs.... 14-1/4 X 25 3blade Stainless Prop. Prop to pad is around 5-1/2 inches below. My problem come when i'm looking for that sweet spot in my steering. The boat jumps out on plane and will run out to about 39 GPS at about WOT...Tack only shows about 4500, not sure if it's correct had to tap on it a few times to get that..I have no problem with the speed i just cant get it to effectively trim out to break loose the steering...I have a feeling it might just be the steering Cables because its a little tight to turn out of the water...Feel free to chime in with any feed back....Thanks for the input if any!
