HVAC Cruiser
- Sep 12, 2009
- 1,254
Re: 21 or 20p 4 blade
I can power up to plane without any slip
with pic 2 from the point its at if I gun it ( I haven't really nailed it just tried to slide up to it so to speak), it hits about 4k and blows out and I have to back down not to break anything it almost feels and sounds like I missed a gear shifting, revs go up boat slows down and its get off the throttle before I blow something up. another way to describe it is over centering a clutch when power shifting a car & it can't take the torque & centrifugal force
I just watched my videos again. The 1st one was just coming out of the channel and easing up to 20-25. my wife took the pic of me driving at the time, its the one in my avatar I wasn't even 1/2 throttle. the 2nd one I was doing about 28 just cruising.
The engine and the drive are still fresh with only 7hrs now on them I climb up nice and slow I have never tried to just jump on it. I am going to try to get out on sunday by myself in the morning, I will do some more tests and give it a shot. I don't want to give my kids heart failure lol.
As it is now even with the problems I am having, when I go from idle to 2k fast it will pin you to your seat, last time I did that my son called me a maniac lol, its not that your going fast, just feels like it is hehehe.
I am going to order the new prop I will get the 23 4 blade you linked to ??.
Right now I have the old iron manifold on her I do have a torquer manifold, high flow open plenum I will toss on to get some more power out of her if needed.
According to the comp cams software with the std manifold I am doing 440 ftlbs torque at 2000 rpm & 312hp@ 4000,...... Hum, I wonder there is that magic # again 4k . Switching to the torquer manifold Not the torquer II, I have the old style
, would slide the curve to 443 ftlbs @ 3500 & 338hp @ 4500
Another thing I think I am going to do is go to a public scale and weigh the trailer and boat, get a transient slip for a day and go back and weigh just the trailer to get a true weight on the boat.
Thats really is a WAG....But you have a cam that should not run out of steam at the top and if it does...well eldobrock performer will fix that..Personally i would stay with a 4 blade, your pushing 4000 plus lbs you need blade area and lift that hull looks like a deep v so lift will only aid in planing...
I watched the video and your bow is up and it looks like your just getting on plane....Is that the break point..thats not 39mph or 4000 i hope..If it is you have spun hubs...aka your climbing ontop of the pressure wave and the prop lets loose
Pic 1 your climbing out...is it slipping at all..Is that full throttle??
Pic 2 your on plane...Is the prop now slipping if you gun it a bit?
1.Can you slam the throtte and power to plane with no slip
2.Do you have to ease it to plane or she starts slipping
I am wondering here if your not being kind to your new motor and gently applying power getting you around...masking a spun hub or some issue...You should be able to nail it from and it should respond sharply with that much tourqe say for 20 to 40 no slip what so ever...Then this would all make sense that is it blows at 40 even gently nudging it past that speed creates cav
What would happen if you just pinned the throttle form 0 to 35 would it slip or cavitate????
