Re: 20hp mercury 1988
Spray some premixed gas into the carb throat, and try it..If it sputters, no fuel is getting past thwe carb..Could vbe fuel pump, carb, or plugged filters.<br /><br />Check for spark,using a spark plug with it's base clipped to ground. DO NOT try to determine spark with the air-gap method (can blow the finicky switchbox).<br />If ity has no spark, the switchbox,coils,kill switch,wires to and from the kill switch,stator,trigger, or the trigger/stator themselves are suspect..Geeezz..I hope it's fuel.<br /><br />Good luck, and let us know what u find.
