mattsjohnson
Thread starter- Joined
- May 27, 2011
- 9
Hi guys, I recently posted about a 1966 20 hp johnson that had 58#s, and 60#s of compression on cylinders, good spark but wouldn't start even if I sprayed gas or starting fluid in the carb. only a backfire. I was concerned with the compression,(if it was enough to start?) but some one replied about the clue of the backfire and questioned the plug wires, I only assumed the wires were hooked up right when I bought it. WRONG!! 60lbs. is enough compression to start but you wouldnt want to run it long without a rebuild. Oh and the rear coil matches to the top cylinder. and the front coil to the bottom. I hope this helps someone as it did me. Thanks.
