20hp Johnson 1983 - Push Button Start Wiring
ScottyOMC
Hello everyone,
I have done some work on quite a few older OMC outboards but I am brand new to the wiring of any electrical wiring in them.
I recently purchased this outboard and it was previously wired for a side console/key start but I would like to wire it up to be a push button start.
Could anyone give me a rundown on how to wire this up? I have attached pictures of the motor and the button.
Thank you very much for any help!
Crosbyman
basically the selenoid must be enegized with one side grounded via or not ... a safety device to prevent starting in gear or high throttle
a fused source of battery +12v under control of your new switch routed to the control post (the other being grounded of course) will energize the seledoid.
see basic (typical) layout follow the greenish /red from the selenoid control post back to the switch S position.
all your new switch will do is forego (duplicate) the front mounted one by sending +12v to the control post .
if your engine needs other connectivity to work make certain other needs are met otherwise it will spin but not start
From the solenoid battery + side you feed 12 volts to your push button switch.------From the push button switch you go to one small post on the solenoid. ---From the other post you go to one spade on the neutral ( white plastic ) safety switch.----Note the safety switch only needs ONE WIRE !!
