20hp 81 Chrysler outboard.. Is the ignition switch universal?
Bishop85
I have the older but reliable chrysler 20hp outboard that either has a bad spot on the starter or a bad ignition switch. Is the ignition switch (what the key goes in (which also is a push to choke)) universal on this engine or does it need one specifically made for it? Also where would I find one....Thanks :)
Frank Acampora
Re: 20hp 81 Chrysler outboard.. Is the ignition switch universal?
Standard 6 terminal push to choke switch. Find one right here at iboats store.
