Green flag!
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #21 Green flag!
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #22 Lap 25 Comp. Caution. Larson led all laps and Elliott is up to 13th.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #23 It looked like Joey had contact leaving his stall. His car did a jiggle.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #24 TWT was speeding on pit road. On the restart, about halfway back, a car (#1?) got loose and collected a bunch. As Jayski says; https://twitter.com/i/web/status/1449804742377545732
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #25 Finally back to green with Truex taking over in front.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #26 Now Byron leads with 62 to go in heat 1.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #27 Leaders are doing splash and goes with 10 to go in the heat. Some get tires. TWT new leader. 8 to go.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #28 TWT gambled on gas and won heat #1.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #29 Debris caution for a quicky. Larson leads.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #30 Larson wins heat 2 with Bryon almost beating the 5 to the line.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #31 Larson leads the restart. Keso had to pit quickly with left tires going down.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #32 Caution for Briscoe slapping the outside wall and letting the air out of the rear tire. 57 to go.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #33 Larson holds the restart lead. 52 to go
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #34 Joey behind the wall with a blown motor. Yellow for clean up and 34 to go.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #35 Restart and Buescher spins. Only him but some flames from a broken off fuel filler. TWT ran into Buescher to start it. Red flag.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #36 Alfredo was the torch.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #37 Back to green. Larso leading. 3 wide and Hamlin has a rub. Larson is leading.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #38 Hamlin pops the tire. but the body may be OK.
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #39 Under yellow with 19 to go. More chaos on the restart?
GA_Boater Honorary Moderator Emeritus Thread starter Joined May 24, 2011 Messages 49,038 Oct 17, 2021 #40 Larso leads the restart. Truex slams the wall! Suarez just nicked the left rear of the 19 to put it in the wall.
