2015 yamaha 75hp too a 115hp
99yam40
compare part numbers on the motors to see if any are the same.
75 to 90 maybe, but I do not think 75 to 115 would be possible unless you did some major modifications and program changing.
turbos or blowers too
check with some racing forums maybe to see what they say
99yam40
Nitrous oxide or a super charger.
yep, takes more fuel and something to oxidize that extra fuel, (more air or nitrous) and then it all has to exit the motor properly too.
not easy to throw a set of tuned headers on an outboard to help it breath.
ahicks
Not from a practical standpoint. The ONLY possibility, and I'm not REAL sure if it would even work, would be to find a 115 power head (complete w/intake and carbs/fuel injection) and swap it with your 75.
boscoe99
Won't fit.
99yam40
Would you like to be a little more specific?
Engines are the same weight, share bore and stoke dims (I think?), so I thought the blocks might be interchangeable? No?
are they the same part number, they would need to be for all the parts to fit
boscoe99
Blocks are not the same. The exhaust guides that the blocks mount on are not the same.
ahicks
Could it be that older models used the same displacement for the 75/90/115's?
jimmbo
is there any way to change a 75hp outboard 4stroke to a 115hp..??
Yes, unbolt the 75 and replace it with a 115.
Even if the Displacement is the Same, there will plenty of Differences to make the additional HP.
Adding HP at the Top, pretty much results in a Drop in Low Rpm Torque, so even though the Boat would have more HP, the holeshot will be slower.
boscoe99
Are you saying that the torque of an F115 at say 2000 RPM will be less than the torque of an F75 at 2000 RPM?
ahicks
Thinking I was going crazy (again), I looked for myself, and I see that Yamaha is saying the 4 stroke 75/90/115 weight/bore/stroke/displacement ARE the same on this web site. Scroll down to "Specs and Compare"
This leaves me wondering about the info you were sharing? Not looking for a pissing match, just trying to figure out what seems to be quite a discrepancy.
boscoe99
You are looking at the very latest 1.8 liter models.
OP asked about the 2015 models.
