2015 Sun Tracker 22 party barge trailer tire size
jeast1
Need help finding the correct trailer tire size, also rim type, on my 22 ft Sun tracker party barge, Has Sun Tracker two axle trailer, I have it stored 250 miles away and need to get new tires on it.
alldodge
There could be many options, I'm use to seeing the wide short ones which would be 215/60-8 load range C
There on 8 inch wide rims
Hope a fellow tooner chimes in
First, welcome aboard
Second, as AD indicated, there may be about a dozen or so options.
you could try and call a tracker dealer and ask them the typical trailer wheels that went on a 2015 Tracker 22 'toon
MRS
you need to drive down to it with money in hand and buy them there. Probably ST 185 or 175/80R-13.
ahicks
If I were going to GUESS, I would say 20.5x8.00x10 to keep the bunks low to the ground for easy launch/retrieval. Not that heavy of a boat, and tandem axles to boot, so even 6 ply would work.
Krazeehorse
Ahicks....agreed. However there is only a $9 difference (wholesale anyway) from a LRC Carlisle sport trail to a LRE. Personally I'd spend the extra $36 and run a little more air.
bruceb58
I have the exact same boat and trailer. It is not with me right now but I am pretty sure its a 175/80/13
Even the load ranges C or D have a ton of margin. No need to do a load range E. That boat often sits on a single axle trailer with the same tires.
