2014 Bass Tracker Igniton Switch
slick75
Bought the boat new in 2014, Ive had relatively few problems so far. Worst so far has been one of the live well pumps is burned up (I think it got left on by accident).
Took the boat out last weekend and every thing worked fine. Took it out yesterday and everything started out fine but after starting the motor a couple of times I noticed the key started getting stuck, at first it didn't want to engage in the start position, the entire switch assembly would turn. After some wiggling and colorful adjectives I finally got it to engage the starter but when I got to the bot ramp suddenly I couldn't shut the engine off. Same thing, the entire switch would turn. Again, after some jiggling and more gentle verbal coaxing it finally shut off, just without the normal click of the switch and then I had to work to get the key to come out. Now the key is tough to get in and out, and it takes some wiggling to get it to turn.
I'm pretty sure I'm about to order a new switch so I decided to open up the console to see what kind of headache installing a new switch was going to be. To my surprise I learned its a simple wire harness plug and done. Thank God for small miracles, I hate wiring. This is where the real question comes. As soon as I open the console I notice a yellow wire with black stripe with a single male terminal plug hanging coming from the sealed ignition switch. After removing the switch from the console I find also a yellow wire with black stripe with a female terminal right there also, wire tied back with the wires from the boat side.
This is the first time the console has been opened except when Bass Pro installed the HumminBird fish finder before I took delivery of the boat. Presumably this wire has been disconnected the whole time I've owned the boat, from what I can tell I haven't been missing any accessories except the burned up aerator pump.
So what is this mystery wire and should I reconnect it or do I risk bowing up something?
Silvertip
Honorary Supreme Mariner
If the wires were tied back and everything on the boat works, that signifies the wires were tied back for a reason. The obvious next step(s) are 1) leave it alone since everything works or 2) trace the wire to see where it goes. If you snooped under the dash of your car or truck you would find lots of unused connectors which are typically used for options your vehicle does not have. Same with the boat. Remember, boats have two electrical systems: 1) for the engine which includes the harness between the engine and the throttle/shift controller and 2) the one for all of the "boat" related circuits such as instruments and accessories (live wells, bilge pump, radio, locator, etc.) The boat system originates at the battery and is fed by a #8 or #10 wire with a fuse or circuit breaker with a foot or so of the battery.
slick75
I figured, but I also know these connections sometimes come apart, this is a simple crimp type terminal, no clips holding them together. The way they have it tied back seemed like it had the potential to pull apart from vibration or maybe from wire twisting with the switch problem. Also curious if there was an 'accessory' position for future stereo installation or something that is disconnected until needed.
Silvertip
If those connections were needed, something would not be working.
