2013 Suzuki 15HP add charging Coil
butchfig8@
Have 2013 Suzuki 15HP model model DF15A, pull start, want to add charge coil
to charge battery's, Suzuki parts diag shows Part# for flywheel and Recitifier,
but module (Coil) is not listed, but kinda shows it in diagram ??
Has some one done this before Thanks
99yam40
not sure on zukes, but Yamahas call the the coil that drives the spark the charge coil.
lighting coil is what run the lights and charges the battery
may just need a rectifier regulator if you have a lighting coil already
lakensea
Very easy - just visit your local Suzuki dealer and they can fix you up with the charging kit.
