2013 Mercurty 60hp serging after running and sitting
flatcrab
Good evening folks,
2013 60hp Mercury bigfoot 4 stroke efi on a pontoon. For 2 or 3 seasons now it has been doing this. Put it in the water and it runs like a top, we run about 15 minutes or so, park it and hang out and sun for about an hour or 2. After that sometimes it cranks fine, others not so much but as soon as we get out of the no wake zone and put throttle to it she surges real hard. Not a miss, real clean sounding running jumping back and forth about 2,000 rpms. It typically runs out after a bit of running and slowly feathering the throttle up and it goes away until we sit still again.
Relevant stuff:
-no ethanol gas in the 3 years I've had it, always use stabil marine 360
-fuel/water separator added last summer with new lines and bulb, no change
-fuel filter filament did not look bad but just replaced it anyway, no chan
-changed oil last summer
-maybe 50 to 70 hours total
-bought from her dad who bought it new but ran ethanol gas
-new starter last summer, cheap aftermarket working fine
-bulb is tight when this happens and pumping it does not help
-seafoam a couple of times last year with no change
You guys got any ideas on what I could replace or try to get past this?
Thank you,
Richard
