2013 Merc 20hp 4 stroke - Low Compression??
Elliomcmh
Hi,
i have a 2013 Merc 20hp 4 stroke. I decided to check the compression after some vibration at trolling speed. I got 55-60psi on both cylinders, is this normal? I remember my old evinrude compression being significantly higher.
i checked the compression on a cold engine, throttle in the idle position, and had the spark plug in the cylinder I wasn’t checking, not sure if this is the correct procedure.
Thanks for the help!!
Honorary Supreme Mariner
Throttle must be at least half open so test it again.
Elliomcmh
Ok I checked both cylinders with the throttle at 50% and 100%, I’m still getting 55-60psi on both cylinders. I also removed both plugs and tested each cylinder that way at 50% and 100% throttle, and it was still 55-60 psi. Engine was cold, 55 degrees outside.
Something is wrong with your gauge or you have serious engine issues !
Elliomcmh
it’s a new gauge I got off of amazon. I could try buying another gauge tomorrow. Would it idle fine with a little vibration at 1/4 throttle and run fine at top speed if the compression is this bad? It’s on a Tracker Grizzly 1448 and runs 22 mph with a 10p prop.
Elliomcmh
Update: I just tested the compression on my lawn mower, the spec is 160psi and the gauge was right at 160psi, so I guess the gauge is good???
Some trouble shooting needs to be done on that motor.
Elliomcmh
I just did some research and it looks like some of the Tohatsu made mercury small outboards have an automatic compression release, I wonder if that is why it runs ok but has low compression.
