2013 Merc 15hp 4 stroke tiller shift shaft sync.
djmarch
Replaced the water pump, and now I need confirmation from the pros in hoping I got the shift shaft in sync with the tiller arm after the LU is installed. In FWD on the tiller handle the prop rotates clockwise, but clicks on every full rotation, (360). When shifting to N on the tiller handle, the prop rotates freely. When shifting to R on the tiller handle, the prop does not turn clockwise. I'm hoping this is correct before I take it on the water. Is there a procedure for this ? I appreciate all feedback....TIA
