2013 E-Tec 250 (E250DPXABA/S# 5396595) Hard Start
111torrance111
We have a 250 E-Tec that starts and immediately dies, it take about 20 to 25 times of this before the motor catches and stays running. Once running it runs great and will restart within 1 or 2 tries.
Just had it in the shop to have the shift switch changed, also changed plugs and the # 1 coil. Called the dealer back and they said it might be the injectors, that's a very costly process just to be guessing.
We already have a new fuel separator/Fuel pick up pump/Plugs..
What else can we check?
Thanks/Jerry
Honorary Supreme Mariner
Well ---the 6 injectors do not all fail at the same time.----Best to find another shop.----May not be easy to find.----You have looked at fuel filters.-----Charged and tested your battery ?-----Do not crank and crank on this starter as it is easily damaged.
Crosbyman
If it runs great and starts great injectors likely ok. compression likely ok also so you are missing fuel as the 3rdelement.
do you recall when all this issue started? how are the filters ...new ..old... crudded . tank venting ok ?
did you inspect the return filter #7 on the VST ...
(small conical filter in the return nipple on the vst) nipples very easy to snap ..work carefully
check top venting float inside the vst
check for any light on th EMM (should all be off when running)
Crosbyman
you should get the serv manual & EV diagnostic software to see if any faults are logged.
your dealer should have given you a fault log dump (history and current faults) they can just email it to you in PDF format since the EV software keeps a log in their shop system (windows PC).
Faztbullet
Sound like the CPS is not staying synced to flywheel or fuel pressure dropping
Crosbyman
Thanks/Jerry
did you investigate all the possibilities in the SEARCH utility....see link
one test is to pull a a spark plug or two insert a strip of paper in the cyl and start (try to) and see if the strip was wetted with a fuel spray from the injector (s) .
If dry...work backwards for possibilities ....
Injectors need a cleaning (no always necessary to replace $$$$)
111torrance111
Update:
When we had the motor in the shop they replaced the #7 filter, however after reading your reply I wanted to check it. It was clogged with residue that I can only assume came from the gas tank on the boat.
We changed the filter and switched to a new external tank, it didn't change how the motor starts. Could this residue have gotten passed this filter and into another somewhere on the engine?
We did get the motor to start yesterday and let it on the new tank, we're going to try again today and see if there is a difference.
When it was in the shop they also removed the water/fuel separator from below deck and installed a new unit above deck, fuel (from original tank) looked good, so not sure where the residue is coming from.
Jerry
Crosbyman
that filter is on the return fuel supply FROM the injectors.... if your injectors are not clogged :eek: then the return hose must be crumbling !! test it for mushy feeling !!
Mecanic should have known because if this a replacement filter (???) and it ended up clogged so fast then the initial one must have been full of junk also !
any filt from the tank if it passed the water separator....should have been stopped in the primary (side) filter
anything affecting fuel flow isn't going to help with starting/running !
just mho mind you I am not a mechanic just a boater :) yoou should chime in on the ETEC user board
BTW when you had it in shop did the shop give you a dump of the history log to flag any active faults or a list of past faults (logged) ??? if not you should ask for one
111torrance111
Update # 2:
This motor in question was purchased used from a boat shop in San Diego, he now thinks it's the injectors and asked that we drive it down from LA so he can remove/clean/replace the injectors. He also thinks this was the original problem with the boat dying when moving between gears and NOT THE SHIFT SWITCH at $150 (Parts/Labor)
The return fuel line from the injectors to filter #7 looked to be ok, should have the motor back next week (Week of April 4th) and we'll try it again. I will post the results once tested.
The boat shop seems to stand behind his used motors base on yelp help, so we're hopeful that this solves the problem.
Jerry
Crosbyman
Great ! it is now a wait and see... my 75ETEC is 17 years old with no injector issues yet but I guess anything can happen. MINd you I have less than 600 hrs on mine
I would insist on getting a EMM log dump because "thinking" the injectors are the cause is just thinking and guessing. Your engine runs great and starts great ..after it does it does kick in ! Could be a faulty HP pump having a hard time building sufficient pressure to feed the injectors . A pressure test during hard start ups could confirm that.
HP pressure pumps apparently enjoy a bit of extra oil in the fuel (search Oly's brew on the ETEC board) Early ETECs had one oil line dedicated to injecting xd-100 oil in the fuel ... later model stopped doing that.
The log dump could have ... pointed out to the fundamental issue. A simple peak at the EMM LED,s could have helped also.
Keep us posted :)
111torrance111
Final Update...
After having all 6 injectors inspected/cleaned and replace the starting issues have been resolved.
Not all 6 were bad, but none of them passed the inspection completely. Had all 6 cleaned and reinstalled. With injectors failing independently the systems seems to vary from motor/motor.
Anyway, wanted to share the end of our troubles and hope this will help somebody else identify their problems sooner.
Jerry
