Greetings.
I just discovered the forum today out of need since I have a bit of what I believe is a fuel issue with my 2012 Tohatsu (Merc Sea-Pro) 30hp 2-stroke jet. The motor is on a new Solar Strela 420 Expedition and started life as a 25hp unit. I’ve changed out the carb restrictor gasket for a 30hp one and the timing is set at 25 degrees.
If I’m cruising along at 3/4 throttle and I open it right up it runs beautifully at WOT for about 10 seconds then backs off about 10% for a second. If I keep the throttle pinned after that 1 second bog it speeds right back up for 4-6 seconds at WOT then backs off for a second or so. It will keep running like that surging between WOT and off 10% all day with the tiller pinned. Pumping the primer bulb doesn’t change the way it operates. It’s like the float bowl is running out of fuel or the fuel pump can’t quite keep up.
Ive done all the checks I can. I’ve cleaned the carb a couple times. Checked the fuel lines and filter. Fresh 50:1 fuel with some Sea Foam in it. New spark plugs. The carb seems to be working as it should so it’s not an issue with the butterfly valve only partially opening.
I can see the float in the carb can be tweaked a bit but I’m not sure if that could be the issue. The motor was used a couple times per year since new and has very low hours on it. As a 25hp unit it worked great at WOT but since the changes this year as mentioned before it seems to be running out of fuel at what is now WOT. If I back it off slightly from WOT it works great so I think if it was still in 25hp form it would be able to keep up with WOT demands.
Its not mentioned anywhere when talking about the Tohatsu 25-30hp conversions that the reeds in the intake are a different part number between models. Could this be the issue? Something keeps making me think it’s the float in the carb….
I’m open to any suggestions and appreciate anyone taking the time to give me their thoughts on the matter.
