2012 60 Mercury 4-Stroke wont run
tigerbait703
I have a 60 four-stroke, model #1A60413KZ that has me running in circles. I was idling to a new fishing spot when the motor killed and lost all power to everything for the motor. The trim didn't work or anything electrical to the outboard. After removing the cowl I went into the first fuse block I seen and the 15 AMP fuse was blown. I changed it out and everything worked and the motor cranked right off, after idling for another 20-30 seconds the engine killed once again. NO fuse was blown this time, everything works and engine turns over and will not start or even fire any, till the battery would die If I would let it. Not sure what can be causing this. The wires that lead to the 15 AMP fuse are Red and Red/ Light Blue for reference.
