2011 Mercury Mercruiser 3.0
pirates3786
I have a 2011 Mercury Mercruiser 3.0 that I just took out for the second time this year. When I returned, after maybe a five minute ride up the cove, I opened the engine compartment and there was a brown milky looking substance around the flame arrestor side. There is a yellow hose that looks like it connects to the carburetor that has this liquid in the top of hose. The boat ran great. I looked up some info online and read that it could be a cracked block or could be some other things - but would like some opinions. I have included some pictures. Thanks.
Re: 2011 Mercury Mercruiser 3.0
Ayuh,... Welcome Aboard,.... What's the oil level on the dipstick right now,..??
What's the short History on the motor,..??
pirates3786
The oil on dipstick was within normal levels. The oil reservoir was empty, no oil was visible. The same brownish liquid was on the dipstick.
Boat is about 2.5 yrs old, less than 50 hours.
Included a dipstick picture.
oldjeep
have you changed the oil since you owned it? Level would indicate OK but with water in oil. If the thing has been sitting then maybe condensation. The stuff in your spark arrestor came from the ccv at the top of the valve cover, which also indicates water in the oil.
I'd drain the oil , replace it with some cheap stuff/new filter, run it for a bit on the muffs, check it again, drain it and replace it with the good stuff/new filter. Hopefully that'll flush all the moisture out and then you have an idea if it was just a bunch of moisture from the lack of use or if you have a real problem.
oldjeep
Oil reservoir? You mean the drive oil? IF that is empty then you have a whole other unrelated problem.
oldjeep
And on 3rd thought - that clearish amber hose is the "fail" from the fuel pump, but it is possible that the pucking from the ccv is just running down into that hose. Seems unlikely that the foam would be coming from the pump.
achris
More fish than mountain goat
Hi Pirate,
What's you location? Do you have freezes? If so, how was the engine winterized?
Empty drive oil reservoir should have fired off the alarm... How empty is 'empty'?
Chris........
pirates3786
If I change the oil and replace the filter, and run it, if it is a cracked engine block, don't I risk seizing the engine up. And from what I can see when I take the cap off of the oil, I do not see any liquid. But when I wipe the dipstick and insert it and remove it, the oil level stays the same as it did in the picture.
I have a storage compartment between the two seats and when I emptied that out, under the life vests, the same liquid substance was there in the bottom of that compartment. There is a drain hole in the rear of that area that leads to the engine compartment, which has a small amount of that residue in that as well.
When I started it again this July, it would cut off during idling. So today, before riding, we adjusted the idling screw. And after that ride was when I noticed that liquid. do you think adjusting that screw would cause this. If so, how can I fix it. Once we adjusted that screw, it did not cut off when idling ... it ran perfectly.
achris
... do you think adjusting that screw would cause this. If so, how can I fix it. Once we adjusted that screw, it did not cut off when idling ... it ran perfectly.
Adjusting the idle speed would not have caused this....
You need to answer my questions before we can advise you on how to fix it....
pirates3786
I'm in NC. So it does freeze. The boat stays on the boat loft thru winter so we pulled the drain plug, put some stabilizer in the gas. We have two other boats and did the same with them, that is what we have done for years and never had any problem.
As far as the oil, no oil is visible in the reservoir. The temp gauge if i remember correctly appeared normal. was not fluctuating. There were no alarms on the boat during any of the short rides.
oldjeep
Do you mean that you pulled the bilge plug, or you drained the block? The 2011 3.0L would have the 2 blue drain hoses that you disconnect from the panel on the right side of the engine. If you didn't drain those, then you froze your motor.
pirates3786
The boat drain plug in the rear of the boat is what they pulled to drain the water out. I do not think they drained the blue hoses on the right of the engine.
Froze your motor - so you think based off all of this the block is cracked because of a freeze....
I was hoping a gaskset blown, or something else - but from what I am reading online, it seems like it will be the worse scenario.
achris
You leave the engine and manifold full of water during freezing temperatures... Yes, I think you have a cracked engine block....
