2010 Tohatsu MFS6B Carb Rebuild
Sea Rider
Re: 2010 Tohatsu MFS6B Carb Rebuild
If metal no, but do remove all plastics and rubber parts....
Happy Boating
pvanv
Additional info and question. As you could tell from the picture in my first post the carb was pretty dirty. I'm able to believe that my ultrasonic cleaning didn't get everything and that's contributing to the stumbling. My plan is to disassemble and clean again using pvanv's advice of a 4 hour dip and cleaning to see if it helps.
So I went out and bought a bucket of carb cleaner made by "Gunk". There are warning all of it not to put plastic in. So my question is do I have to worry about the linkages and choke plates, etc...? I didn't remove those items for the first cleaning.
Thanks.
You do not need to remove the hard plastic bits, such as the choke actuator arm. They would be very difficult to reinstall anyway :)
Ultrasonic cleaning is fine. Excellent in fact. But what liquid you use is more important, as it needs to be able to dissovle the organic deposits in a reasonable amount of time without etching the anodizing off of the carb.
On a B or C series carb, even if clean as a whistle, it may have a little stumble, under load, especially if not fully warm, and if you really snap the throttle open very briskly. That's a side-effect of the more stringent EPA standards, which forced the engine manufacturers to run even leaner than on the A models. On a varnished carb, the motor might even stall if accelerating too rapidly. However, with a clean carb, if you operate the throttle "normally", allowing say about 2 or 3 seconds to transition from idle to WOT, that should not be a problem.
rsnyder518
I'm glad I don't have to take those parts off. I looked at them and decided that if they needed to come off I was just going to bring it somewhere and be done with it.
I might not be in terrible shape. When I operate the throttle "normally" as you've indicated above I think it's fine. It stumbles hard when I really snap open the throttle. I'll call that the EPA mandated stumble.
But I've got the carb dip and it's pretty easy to take it off for another round of cleaning just to be sure. It's not like it's going to get too clean.
Thanks again everyone! Hopefully be one the water soon!
pvanv
Yes, you can go "too" clean. Don't leave the carb in all day, or you risk etching the anodizing from the aluminum. While that won't hurt initial performance, it will make the carb casting extremely vulnerable to corrosion. Plan on a 4-hour carb bath at room temperature.
rsnyder518
Thanks for the tip. I did the 4 hour dip and subsequent spray down with carb cleaner last night but by the time it was done it was too late to reinstall it on the motor. I think the carb looks better than it did even after the ultrasonic so it was probably worthwhile to go through the extra cleaning. Hopefully I'll be installing it and running the motor tonight.
rsnyder518
Just to close the loop. I did the 4 hour carb dip/cleaning and resintalled. Ran much better, the idle was smoother and the stumble is fixed. As suggested above, perhaps my ulatrasonic cleaning solution was less than ideal.
Thanks to everyone for their help! :) Started a new thread to track a water leak question that I have.
pvanv
Ultrasonic is cool. But the "solvent" media used is even more important (as you found) :)
