2010 SeaRay Engine low voltage
carenter
I have a friend with a 2010 SeaRay. He is getting a code 209 engine low voltage. Every thing comes on but engine will not start. It will not even turn over. We have checked all the fuses, battery is fully charged. gauge show 12 volts but battery has 12.67 volts. Please help
Bt Doctur
Re: 2010 SeaRay Engine low voltage
does it do anything or make any sounds when you turn the key to start?
do the gauges operate in the "on" position?
Don S
going to need some engine and drive info. What your boat is means nothing.
What engine, what drive? Serial numbers are almost mandatory with some questions, especially if you are looking for code numbers.
dingdongs
Check for clean ground and power supply to starter motor.Are the cables tight on starter?
carenter
He has a merc I/O with bravo 3 out drive. It also has smart craft on it. That's what is giving me the code 209. We have checked all the wires today. All are tight. Gauges come on when when key is on. But will not turn over just keeps beeping. And will not turn over. Not even a click from the starter colenoid.
Don S
Thank you for all the wonderful engine information. :facepalm:
dingdongs
jump the solenoid large posts with wrench to see if the starter will swing the engine over.it may be fubar
carenter
The engine is a fuel injected 350. that in all i know about the engine. the boat has push button start. i will call and ask today.
