2010 optimax propeller question
haines565l
Hi I have a 135hp 2010 optimax model #1135d83hy I have just been given a stainless steel laser II prop 19pwithout flo torq which fits on prop shaft fine. Where as my existing prop is a pro torq vengence 17p model So the question id like to ask is if the laser II will still work on my motor? and is there any washers I need to put on where the locking nut goes?
wired247
The laser II should use the same thrust washer that your flo torque hub prop uses. You need the 12-31211A3 washer on the back and the same lock tab you use with the flo torq hub. The whole kit with all the washers and tab,nut etc is 11-827614Q01. Its only about $20.
