2010 Mercruiser 4.3 TKS Drain plug stuck
kjp17
When I went to winterize and remove the plugs this year, one plug was stuck. It was so stuck that the wings broke off. Luckily it was fit into a different piece, that i was able to remove (see picture). I do not know what this piece is actually called, and cannot find an exact match. I also found the piece to be full of black gunk. Any help would be appreciated.
Bt Doctur
Any merc dealer will have that part, comes in a kit with a new plastic plug. That usually happens when:
you install the plug too tight
you install the plug with no grease
you fail to remove the plug for winterizing for a few years.
Hardin Marine sells stainless versions of that @#$%@#$ plug
the black gunk as you call it is common on the insides of motors. this is why you must pull the plugs and probe the drains
that black gunk is why the newer mercruiser single point drain systems will bust your block.
achris
More fish than mountain goat
Newer? That block cracking piece of junk has been around for more than 10 years!
which is newer than the little blue winged plugs in the adapters by a few years.
achris
Yeah, not their finest hour... Fortunately I don't have to deal with any of that bollocks here. 'Winterizing' consists of putting on some warmer tee-shirts... :lol::lol::lol::lol:
(A REALLY cold night is about 5 degrees, 40 in 'Funny' temps)
