2010 Evinrude e-tec 25hp
msb1
2010 Evinrude 25 hp
Model: E25DPLISC
I am fairly sure I have a bad fuel pump. I disassembled the VST / pump assembly and the fuel pump has quite a bit of corrosion on the bottom so I assume on the inside also. I would like to replace just the fuel pump, but can't seem to find anything except the entire VST / pump assembly for around $350. Any ideas?
Numbers on fuel pump:
28128525
0405
5195 A DELPHI IN
